Datasheet Wago 234-203 — Даташит
Клеммная колодка для печатной платы; Кнопка; 0,5 мм²; Шаг контактов 2,5 мм; 3-полюсный; CAGE CLAMP
|  Купить 234-203 на РадиоЛоцман.Цены — от 196 до 297 ₽ 6 предложений от 6 поставщиков 234-203, 3-конт. клеммная колодка, шаг 2,5 мм, наж. рычаг, серая | |||
| 234-203 Wago Оф. дистрибьютор | 196 ₽ | ||
| 2-34203-3 | по запросу | ||
| 234-203 Wago | по запросу | ||
| 234-203 | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 14.4 mm / 0.567 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
| Fire load | 0.025 MJ |
| GTIN | 4044918651493 |
| Height | 18 mm / 0.709 inch |
| Height from the surface | 14 mm / 0.551 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 2.5 mm (0.098 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 63 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 1.623 г |
| Ширина | 9.7 mm / 0.382 inch |
Серия: 234 (29)
- PCB Interconnect
