Datasheet Wago 234-205 — Даташит
Клеммная колодка для печатной платы; Кнопка; 0,5 мм²; Шаг контактов 2,5 мм; 5-полюсный; CAGE CLAMP
![]() 33 предложений от 16 поставщиков Промышленные/Универсальные Реле, Reed Relay 5VDC 175Ω 0.25A DPDT(20.57x5.33x9.7)mm THT Dry | |||
234-205 Wago | 296 ₽ | ||
234-205 Wago Оф. дистрибьютор | 350 ₽ | ||
2342-05-000 | от 1 164 ₽ | ||
2342-05-000 | по запросу |
Actuation type | Push-button |
Цвет | gray |
Conductor entry angle to the PCB | 90 ° |
Country of origin | CH |
Габариты: глубина | 14.4 mm / 0.567 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
Fire load | 0.039 MJ |
GTIN | 4044918651516 |
Height | 18 mm / 0.709 inch |
Height from the surface | 14 mm / 0.551 inch |
Material group | I |
Number of Poles | 5 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 2.5 mm (0.098 inch) |
Rated current | 6 A |
Rated voltage (III / 3) | 63 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Total number of connection points | 5 |
Total number of potentials | 5 |
Вес | 2.615 г |
Ширина | 14.7 mm / 0.579 inch |
Серия: 234 (29)
- PCB Interconnect
