Datasheet Wago 234-524 — Даташит
Серия234
Модель234-524
Клеммная колодка для печатной платы; Кнопка; 0,5 мм²; Шаг контактов 2,54 мм; 24-полюсный; CAGE CLAMP
Axial Lead and Cartridge Fuses - Designed to UL/CSA Standards
Littelfuse
Actuation typePush-button
Цветorange
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originCH
Габариты: глубина14.4 mm / 0.567 inch
Fine-stranded conductor0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 mm²
Fire load0.172 MJ
GTIN4044918652322
Height18 mm / 0.709 inch
Height from the surface14 mm / 0.551 inch
Material groupI
Number of Poles24
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing2.54 mm (0.1 inch)
Rated current6 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)63 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.08 … 0.5 mm² / 28 … 20 AWG
Total number of connection points24
Total number of potentials24
Вес12.2 г
Ширина63.16 mm / 2.487 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 234-524
