Datasheet Wago 235-102/330-000 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,81 мм; 2-полюсный; ПРОВОД НАЖИМАЕТСЯ
PCB TERMINAL BLOCK; 1.5 MM; PIN | |||
235-102/330-000 Wago | 65 ₽ | ||
235-102/330-000 Wago | по запросу |
Цвет | orange |
Connection technology | PUSH WIRE® |
Country of origin | CN |
Габариты: глубина | 12.5 mm / 0.492 inch |
Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² |
Fire load | 0.02 MJ |
GTIN | 4044918828338 |
Height | 12.8 mm / 0.504 inch |
Height from the surface | 9.2 mm / 0.362 inch |
Material group | I |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 3.81 mm (0.15 inch) |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 500 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 200 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.8 x 0.4 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 2 |
Total number of potentials | 2 |
Вес | 1.166 г |
Ширина | 9.12 mm / 0.359 inch |
Серия: 235 (100 из 185)
- 235-100 235-101 235-101/330-000 235-102 235-102/330-000 235-103 235-103/330-000 235-104 235-104/330-000 235-105 235-105/330-000 235-106 235-106/330-000 235-107 235-107/330-000 235-108 235-108/330-000 235-109 235-109/330-000 235-110 235-110/330-000 235-112 235-116 235-200 235-201 235-202 235-203 235-204 235-206 235-207 235-208 235-209 235-212 235-216 235-300 235-316 235-400 235-401 235-401/331-000 235-401/332-000 235-401/333-000 235-402 235-402/331-000 235-402/332-000 235-402/333-000 235-403 235-403/331-000 235-403/332-000 235-404 235-404/000-006 235-404/331-000 235-404/333-000 235-405 235-405/331-000 235-405/333-000 235-406 235-406/331-000 235-407 235-407/331-000 235-408 235-408/331-000 235-408/332-000 235-408/333-000 235-409 235-409/331-000 235-409/332-000 235-410 235-410/331-000 235-412 235-412/331-000 235-416 235-416/331-000 235-452 235-452/331-000 235-453 235-453/331-000 235-454 235-454/331-000 235-455/331-000 235-456 235-458/331-000 235-459/331-000 235-460/331-000 235-462/331-000 235-500 235-501 235-501/331-000 235-501/332-000 235-501/333-000 235-502 235-502/331-000 235-503/331-000 235-504 235-504/331-000 235-505/331-000 235-506/331-000 235-508/331-000 235-550 235-551 235-551/331-000
- PCB Interconnect
235102/330000, 235 102/330 000
