Datasheet Wago 235-107/330-000 — Даташит
Серия235
Модель235-107/330-000
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,81 мм; 7-полюсный; PUSH WIRE
Actuation typeOperating tool
Цветorange
Connection technologyPUSH WIRE®
Contact platingtin-plated
Country of originCH
Габариты: глубина12.5 mm / 0.492 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm²
Fire load0.06 MJ
GTIN4044918828741
Height12.8 mm / 0.504 inch
Height from the surface9.2 mm / 0.362 inch
Material groupI
Number of Poles7
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing3.81 mm (0.15 inch)
Rated current17.5 A
Rated voltage (II / 2)500 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)200 В
Solder pin dimensions0.8 x 0.4 mm
Solder pin length3.6 мм
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points7
Total number of potentials7
Вес3.756 г
Ширина28.17 mm / 1.109 inch
  • PCB Interconnect
235107/330000, 235 107/330 000
На английском языке: Datasheet Wago 235-107/330-000
