Datasheet Wago 235-112 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,81 мм; 12-полюсный; Зажим Push-in CAGE CLAMP
Купить 235-112 на РадиоЛоцман.Цены — от 28 до 1 000 ₽22 предложений от 14 поставщиков Аксессуары: гайка; для монтажа банановых гнезд на панели | |||
| 2-35112-2 TE Connectivity | 36 ₽ | ||
| 2-35112-2 Tyco | 95 ₽ | ||
| 2-35112-2 TE Connectivity | от 117 ₽ | ||
| 2-35112-2 TE Connectivity | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 12.5 mm / 0.492 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.75 … 1.5 mm² / 20 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.124 MJ |
| GTIN | 4044918829007 |
| Height | 19.1 mm / 0.752 inch |
| Height from the surface | 15.5 mm / 0.61 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 3.81 mm (0.15 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 500 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 200 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.4 x 0.8 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Вес | 7.038 г |
| Ширина | 47.22 mm / 1.859 inch |
Серия: 235 (100 из 185)
- 235-100 235-101 235-101/330-000 235-102 235-102/330-000 235-103 235-103/330-000 235-104 235-104/330-000 235-105 235-105/330-000 235-106 235-106/330-000 235-107 235-107/330-000 235-108 235-108/330-000 235-109 235-109/330-000 235-110 235-110/330-000 235-112 235-116 235-200 235-201 235-202 235-203 235-204 235-206 235-207 235-208 235-209 235-212 235-216 235-300 235-316 235-400 235-401 235-401/331-000 235-401/332-000 235-401/333-000 235-402 235-402/331-000 235-402/332-000 235-402/333-000 235-403 235-403/331-000 235-403/332-000 235-404 235-404/000-006 235-404/331-000 235-404/333-000 235-405 235-405/331-000 235-405/333-000 235-406 235-406/331-000 235-407 235-407/331-000 235-408 235-408/331-000 235-408/332-000 235-408/333-000 235-409 235-409/331-000 235-409/332-000 235-410 235-410/331-000 235-412 235-412/331-000 235-416 235-416/331-000 235-452 235-452/331-000 235-453 235-453/331-000 235-454 235-454/331-000 235-455/331-000 235-456 235-458/331-000 235-459/331-000 235-460/331-000 235-462/331-000 235-500 235-501 235-501/331-000 235-501/332-000 235-501/333-000 235-502 235-502/331-000 235-503/331-000 235-504 235-504/331-000 235-505/331-000 235-506/331-000 235-508/331-000 235-550 235-551 235-551/331-000
- PCB Interconnect
