Datasheet Wago 235-404/333-000 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5/5,08 мм; 4-полюсный; ПРОВОД PUSH
| Купить 235-404 на РадиоЛоцман.Цены — от 105 до 261 ₽ 12 предложений от 8 поставщиков Клеммная колодка типа провод к плате, 5.08 мм, 4 вывод(-ов), 20 AWG, 14 AWG, 1.5 мм², Вставной | |||
| 235-404/331-000 Wago | от 261 ₽ | ||
| 235-404 Wago | по запросу | ||
| 235-404/332-000 Littelfuse | по запросу | ||
| 235-404 Littelfuse | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | PUSH WIRE® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 12.5 mm / 0.492 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.048 MJ |
| GTIN | 4044918830164 |
| Height | 12.8 mm / 0.504 inch |
| Height from the surface | 9.2 mm / 0.362 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.8 x 0.4 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 4 |
| Вес | 2.85 г |
| Ширина | 21.5 mm / 0.846 inch |
Серия: 235 (100 из 185)
- 235-101 235-101/330-000 235-102 235-102/330-000 235-103 235-103/330-000 235-104 235-104/330-000 235-105 235-105/330-000 235-106 235-106/330-000 235-107 235-107/330-000 235-108 235-108/330-000 235-109 235-109/330-000 235-110 235-110/330-000 235-112 235-116 235-200 235-201 235-202 235-203 235-204 235-206 235-207 235-208 235-209 235-212 235-216 235-300 235-316 235-400 235-401 235-401/331-000 235-401/332-000 235-401/333-000 235-402 235-402/331-000 235-402/332-000 235-402/333-000 235-403 235-403/331-000 235-403/332-000 235-404 235-404/000-006 235-404/331-000 235-404/333-000 235-405 235-405/331-000 235-405/333-000 235-406 235-406/331-000 235-407 235-407/331-000 235-408 235-408/331-000 235-408/332-000 235-408/333-000 235-409 235-409/331-000 235-409/332-000 235-410 235-410/331-000 235-412 235-412/331-000 235-416 235-416/331-000 235-452 235-452/331-000 235-453 235-453/331-000 235-454 235-454/331-000 235-455/331-000 235-456 235-458/331-000 235-459/331-000 235-460/331-000 235-462/331-000 235-500 235-501 235-501/331-000 235-501/332-000 235-501/333-000 235-502 235-502/331-000 235-503/331-000 235-504 235-504/331-000 235-505/331-000 235-506/331-000 235-508/331-000 235-550 235-551 235-551/331-000 235-551/332-000
- PCB Interconnect
235404/333000, 235 404/333 000
