Datasheet Wago 235-502/331-000 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 7,5/7,62 мм; 2-полюсный; Вставной зажим CAGE CLAMP
PCB TERMINAL BLOCK; 2.5 MM; PIN / 2 Position Wire to Board Terminal Block Horizontal with Board 0.300 (7.62mm) Through Hole... | |||
235-502 Wago | по запросу | ||
235-502 | по запросу | ||
235-502 Littelfuse | по запросу | ||
Actuation type | Push-button |
Цвет | gray |
Country of origin | CN |
Габариты: глубина | 12.5 mm / 0.492 inch |
Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
Fine-stranded conductor | 0.75 … 1.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
Fire load | 0.041 MJ |
GTIN | 4044918830584 |
Height | 19.1 mm / 0.752 inch |
Height from the surface | 15.5 mm / 0.61 inch |
Material group | I |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 400 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.4 x 0.8 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.2 … 1.5 mm² / 20 … 14 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 2 |
Total number of potentials | 2 |
Вес | 1.958 г |
Ширина | 16.5 mm / 0.65 inch |
Серия: 235 (100 из 185)
- 235-401/333-000 235-402 235-402/331-000 235-402/332-000 235-402/333-000 235-403 235-403/331-000 235-403/332-000 235-404 235-404/000-006 235-404/331-000 235-404/333-000 235-405 235-405/331-000 235-405/333-000 235-406 235-406/331-000 235-407 235-407/331-000 235-408 235-408/331-000 235-408/332-000 235-408/333-000 235-409 235-409/331-000 235-409/332-000 235-410 235-410/331-000 235-412 235-412/331-000 235-416 235-416/331-000 235-452 235-452/331-000 235-453 235-453/331-000 235-454 235-454/331-000 235-455/331-000 235-456 235-458/331-000 235-459/331-000 235-460/331-000 235-462/331-000 235-500 235-501 235-501/331-000 235-501/332-000 235-501/333-000 235-502 235-502/331-000 235-503/331-000 235-504 235-504/331-000 235-505/331-000 235-506/331-000 235-508/331-000 235-550 235-551 235-551/331-000 235-551/332-000 235-551/333-000 235-552/331-000 235-553 235-600 235-650 235-700 235-701 235-711 235-711/331-000 235-711/332-000 235-711/333-000 235-712 235-712/331-000 235-713 235-713/331-000 235-714 235-714/331-000 235-716 235-716/331-000 235-717 235-717/331-000 235-722 235-722/331-000 235-723 235-723/331-000 235-724 235-724/331-000 235-726 235-726/331-000 235-727 235-727/331-000 235-740 235-740/331-000 235-741/331-000 235-742 235-742/331-000 235-743 235-743/331-000 235-744
- PCB Interconnect
235502/331000, 235 502/331 000
