Datasheet Wago 235-726/331-000 — Даташит
Стекируемый 2-проводной клеммный блок для печатной платы; Кнопка; 0,75 мм²; Шаг контактов 7,5/7,62 мм; 1-полюсный; PUSH WIRE
| STACKABLE 2-CONDUCTOR PCB TERMIN | |||
| 235-726/331-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connection technology | PUSH WIRE® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 12.5 mm / 0.492 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fire load | 0.02 MJ |
| GTIN | 4044918832106 |
| Height | 19.1 mm / 0.752 inch |
| Height from the surface | 15.5 mm / 0.61 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 400 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.8 x 0.4 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 0.75 mm² / 24 … 18 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Вес | 0.958 г |
| Ширина | 9 mm / 0.354 inch |
Серия: 235 (100 из 185)
- 235-456 235-458/331-000 235-459/331-000 235-460/331-000 235-462/331-000 235-500 235-501 235-501/331-000 235-501/332-000 235-501/333-000 235-502 235-502/331-000 235-503/331-000 235-504 235-504/331-000 235-505/331-000 235-506/331-000 235-508/331-000 235-550 235-551 235-551/331-000 235-551/332-000 235-551/333-000 235-552/331-000 235-553 235-600 235-650 235-700 235-701 235-711 235-711/331-000 235-711/332-000 235-711/333-000 235-712 235-712/331-000 235-713 235-713/331-000 235-714 235-714/331-000 235-716 235-716/331-000 235-717 235-717/331-000 235-722 235-722/331-000 235-723 235-723/331-000 235-724 235-724/331-000 235-726 235-726/331-000 235-727 235-727/331-000 235-740 235-740/331-000 235-741/331-000 235-742 235-742/331-000 235-743 235-743/331-000 235-744 235-744/331-000 235-745/331-000 235-746 235-746/331-000 235-747 235-747/331-000 235-748/331-000 235-749/331-000 235-752 235-752/331-000 235-753 235-753/331-000 235-754 235-754/331-000 235-756 235-756/331-000 235-757 235-757/331-000 235-758/331-000 235-762 235-762/331-000 235-764/331-000 235-766 235-766/331-000 235-767/331-000 235-770 235-771 235-772 235-774 235-775 235-776 235-777 235-778 235-800 235-801 235-801/331-000 235-801/332-000 235-801/333-000 235-802
- PCB Interconnect
235726/331000, 235 726/331 000
