Datasheet Wago 236-401/332-000 — Даташит
Стекируемый клеммный блок для печатных плат; 2,5 мм²; Шаг контактов 5/5,08 мм; 1-полюсный; CAGE CLAMP; возможность объединения
STACKABLE PCB TERMINAL BLOCK; 2. | |||
| 236-401/332-000 Wago | по запросу | ||
| 236-401/332-000 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 14 mm / 0.551 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.012 MJ |
| GTIN | 4044918775953 |
| Height | 18.5 mm / 0.728 inch |
| Height from the surface | 13 mm / 0.512 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 5.5 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 0.869 г |
| Ширина | 7.2 mm / 0.283 inch |
Серия: 236 (100 из 244)
- 236-100 236-101 236-102 236-103 236-104 236-105 236-106 236-107 236-108 236-109 236-112 236-114 236-114/000-008 236-116 236-124 236-136 236-148 236-200 236-201 236-202 236-203 236-204 236-205 236-206 236-207 236-208 236-209 236-212 236-216 236-224 236-300 236-301 236-302 236-303 236-304 236-305 236-306 236-307 236-308 236-309 236-312 236-316 236-324 236-400 236-401 236-401/332-000 236-402 236-402/000-005 236-402/000-009/999-950 236-402/332-000 236-402/332-009/999-950 236-402/334-604 236-402/334-604/997-405 236-403 236-403/000-009/999-950 236-403/332-000 236-403/332-009/999-950 236-403/334-604 236-403/334-604/997-405 236-404 236-404/000-009/999-950 236-404/000-015 236-404/332-000 236-404/332-009/999-950 236-404/334-604 236-404/334-604/997-406 236-405 236-405/334-604 236-405/334-604/997-406 236-406 236-406/000-009/999-950 236-406/332-000 236-406/332-009/999-950 236-406/334-023 236-406/334-604 236-406/334-604/997-406 236-407 236-408 236-408/000-009/999-950 236-408/332-000 236-408/332-009/999-950 236-408/334-023 236-409 236-409/334-604 236-412 236-412/000-009/999-950 236-412/332-000 236-412/332-009/999-950 236-416 236-416/000-009/999-950 236-416/332-009/999-950 236-416/334-023 236-424 236-424/000-009/999-950 236-424/332-009/999-950 236-436 236-436/000-009/999-950 236-436/332-009/999-950 236-441 236-448
- PCB Interconnect
236401/332000, 236 401/332 000
