Datasheet Wago 236-403/334-604 — Даташит
Серия236
Модель236-403/334-604
Клеммная колодка THR PCB; 2,5 мм²; Шаг контактов 5/5,08 мм; 3-полюсный; CAGE CLAMP; возможность объединения
236-403/334-604/997-405
Actuation typeOperating tool
Цветblack
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originCH
Габариты: глубина14 mm / 0.551 inch
Fine-stranded conductor with ferrule without plastic collar0.25 … 1.5 mm²
Fire load0.043 MJ
Flammability class per UL94V2
GTIN4044918769235
Height16.6 mm / 0.654 inch
Height from the surface13 mm / 0.512 inch
Insulating materialPolyamide 46 (PA 46)
Limit temperature range-60 … +115 °C
Material groupIII a
Number of Poles3
Number of connection types1
Number of levels1
PCB contactTHR
Pin spacing5 mm / 0.197 inch
Plated through-hole diameter (THR)1.1 (+ 0.1) мм
Rated current24 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)200 В
Solder pin dimensions0.7 x 0.7 mm
Solder pin length3.6 мм
Total number of connection points3
Total number of potentials3
Вес2.795 г
Ширина17.3 mm / 0.681 inch
  • PCB Interconnect
236403/334604, 236 403/334 604
На английском языке: Datasheet Wago 236-403/334-604
