Datasheet Wago 236-424 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5/5,08 мм; 24-полюсный; CAGE CLAMP; возможность объединения
PCB TERMINAL BLOCK; 2.5 MM; PIN | |||
| 236-424 Wago | по запросу | ||
| 236-424 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 14 mm / 0.551 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.292 MJ |
| GTIN | 4044918771504 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 13 mm / 0.512 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 24 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 24 |
| Total number of potentials | 24 |
| Вес | 21.196 г |
| Ширина | 122.3 mm / 4.815 inch |
Серия: 236 (100 из 244)
- 236-324 236-400 236-401 236-401/332-000 236-402 236-402/000-005 236-402/000-009/999-950 236-402/332-000 236-402/332-009/999-950 236-402/334-604 236-402/334-604/997-405 236-403 236-403/000-009/999-950 236-403/332-000 236-403/332-009/999-950 236-403/334-604 236-403/334-604/997-405 236-404 236-404/000-009/999-950 236-404/000-015 236-404/332-000 236-404/332-009/999-950 236-404/334-604 236-404/334-604/997-406 236-405 236-405/334-604 236-405/334-604/997-406 236-406 236-406/000-009/999-950 236-406/332-000 236-406/332-009/999-950 236-406/334-023 236-406/334-604 236-406/334-604/997-406 236-407 236-408 236-408/000-009/999-950 236-408/332-000 236-408/332-009/999-950 236-408/334-023 236-409 236-409/334-604 236-412 236-412/000-009/999-950 236-412/332-000 236-412/332-009/999-950 236-416 236-416/000-009/999-950 236-416/332-009/999-950 236-416/334-023 236-424 236-424/000-009/999-950 236-424/332-009/999-950 236-436 236-436/000-009/999-950 236-436/332-009/999-950 236-441 236-448 236-448/000-009/999-950 236-448/332-000 236-448/332-009/999-950 236-500 236-501 236-501/332-000 236-502 236-502/000-004 236-502/000-009/999-950 236-502/332-000 236-502/332-009/999-950 236-503 236-503/000-009/999-950 236-503/000-015 236-503/332-000 236-503/332-009/999-950 236-504 236-504/000-009/999-950 236-504/332-000 236-504/332-009/999-950 236-505 236-506 236-506/000-009/999-950 236-506/332-009/999-950 236-507 236-508 236-508/000-009/999-950 236-508/332-009/999-950 236-509 236-512 236-512/000-009/999-950 236-512/332-009/999-950 236-516 236-516/000-009/999-950 236-516/332-009/999-950 236-524 236-524/000-009/999-950 236-524/332-009/999-950 236-600 236-601 236-601/332-000 236-602
- PCB Interconnect
