Datasheet Wago 236-448/332-000 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5/5,08 мм; 48-полюсный; CAGE CLAMP; возможность объединения
PCB TERMINAL BLOCK; 2.5 MM; PIN | |||
236-448 Wago | 1 304 ₽ | ||
236-448 | по запросу | ||
236-448 Wago | по запросу |
Цвет | gray |
Country of origin | CH |
Габариты: глубина | 14 mm / 0.551 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.58 MJ |
GTIN | 4044918776189 |
Height | 18.5 mm / 0.728 inch |
Height from the surface | 13 mm / 0.512 inch |
Material group | I |
Number of Poles | 48 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 5.5 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 48 |
Total number of potentials | 48 |
Вес | 41.86 г |
Ширина | 242.3 mm / 9.539 inch |
Серия: 236 (100 из 244)
- 236-402/334-604 236-402/334-604/997-405 236-403 236-403/000-009/999-950 236-403/332-000 236-403/332-009/999-950 236-403/334-604 236-403/334-604/997-405 236-404 236-404/000-009/999-950 236-404/000-015 236-404/332-000 236-404/332-009/999-950 236-404/334-604 236-404/334-604/997-406 236-405 236-405/334-604 236-405/334-604/997-406 236-406 236-406/000-009/999-950 236-406/332-000 236-406/332-009/999-950 236-406/334-023 236-406/334-604 236-406/334-604/997-406 236-407 236-408 236-408/000-009/999-950 236-408/332-000 236-408/332-009/999-950 236-408/334-023 236-409 236-409/334-604 236-412 236-412/000-009/999-950 236-412/332-000 236-412/332-009/999-950 236-416 236-416/000-009/999-950 236-416/332-009/999-950 236-416/334-023 236-424 236-424/000-009/999-950 236-424/332-009/999-950 236-436 236-436/000-009/999-950 236-436/332-009/999-950 236-441 236-448 236-448/000-009/999-950 236-448/332-000 236-448/332-009/999-950 236-500 236-501 236-501/332-000 236-502 236-502/000-004 236-502/000-009/999-950 236-502/332-000 236-502/332-009/999-950 236-503 236-503/000-009/999-950 236-503/000-015 236-503/332-000 236-503/332-009/999-950 236-504 236-504/000-009/999-950 236-504/332-000 236-504/332-009/999-950 236-505 236-506 236-506/000-009/999-950 236-506/332-009/999-950 236-507 236-508 236-508/000-009/999-950 236-508/332-009/999-950 236-509 236-512 236-512/000-009/999-950 236-512/332-009/999-950 236-516 236-516/000-009/999-950 236-516/332-009/999-950 236-524 236-524/000-009/999-950 236-524/332-009/999-950 236-600 236-601 236-601/332-000 236-602 236-602/000-009/999-950 236-602/332-000 236-602/332-009/999-950 236-603 236-603/000-004 236-603/000-009/999-950 236-603/000-017 236-603/332-009/999-950 236-604
- PCB Interconnect
236448/332000, 236 448/332 000
