Datasheet Wago 237 — Даташит
Серия237
Datasheet Wago 237
16 предложений от 5 поставщиков
PCB TERMINAL BLOCK; 2.5 MM; PIN
Зенер
Россия и страны ТС
237102
от 184 ₽
Элитан
225 ₽
237-102
Parameters / Models237-102
237-102
237-103
237-103
237-104
237-104
237-112
237-112
237-113
237-113
237-132
237-132
237-133
237-133
237-136
237-136
237-142
237-142
237-146
237-146
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraygraygraygraygraygraygraygraygray
Connection technologyScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connectionScrew clamp connection
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originININDEININININDEIN
Габариты: глубина9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch9 mm / 0.354 inch
Fine-stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG
Fire load, MJ0.0120.016
Flammability class per UL94V0V0V0V0V0V0V0V0V0
GTIN4045454539771404545453978840173322697354044918683203404545453984940454545399004017332269766404545453995540449186832584045454539979
Height from the surface11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch11 mm / 0.433 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIII
Number of Poles231223613
Number of connection types111111111
Number of levels111111111
Number of solder pins per potential111111111
PCB contactTHTTHTTHTTHTTHTTHTTHTTHTTHT
Pin spacing5/5.08 mm / 0.197/0.2 inch5/5.08 mm / 0.197/0.2 inch10/10.16 mm / 0.394/0.4 inch10/10.16 mm / 0.394/0.4 inch5/5.08 mm / 0.197/0.2 inch5/5.08 mm / 0.197/0.2 inch5/5.08 mm / 0.197/0.2 inch10/10.16 mm / 0.394/0.4 inch10/10.16 mm / 0.394/0.4 inch
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A161616161616161616
Rated impulse voltage (III / 2), kV2.52.5662.52.52.562.5
Rated voltage (III / 2), В250250800800250250250800800
Solder pin arrangementover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in line
Solid conductor0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG0.5 … 2.5 mm² / 20 … 14 AWG
Strip length5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch5 … 7 mm / 0.2 … 0.28 Inch
Total number of connection points231223613
Total number of potentials231223613
Вес, г1.8632.8980.4071.262.152.043.085.7161.2833.823
Ширина5 mm / 0.197 inch5 mm / 0.197 inch10 mm / 0.394 inch10 mm / 0.394 inch5.08 mm / 0.2 inch5.08 mm / 0.2 inch5 mm / 0.197 inch10 mm / 0.394 inch10 mm / 0.394 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 237
