Datasheet Wago 237-133 — Даташит
Модульная клеммная колодка; с защитой проводов; 3-полюсная; Шаг контактов 5,08 мм / 0,2 дюйма
| RETAINING PIN | |||
| 237133 TE Connectivity | 4 414 ₽ | ||
| 2.37133e+007 | по запросу | ||
| 237133 TE Connectivity | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Screw clamp connection |
| Contact material | Electrolytic copper (Ecu) |
| Габариты: глубина | 9 mm / 0.354 inch |
| Fine-stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| GTIN | 4017332269766 |
| Height from the surface | 11 mm / 0.433 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Rated current | 16 A |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated voltage (III / 2) | 250 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solid conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| Strip length | 5 … 7 mm / 0.2 … 0.28 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 3.08 г |
| Ширина | 5.08 mm / 0.2 inch |
- PCB Interconnect
