Datasheet Wago 237-146 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 3-полюсный
| Купить 237-146 на РадиоЛоцман.Цены — от 3 656 до 4 290 ₽ , NPT1 1/4"HPMULTI CALBECORDGRIP | |||
| 23714.6 | 3 656 ₽ | ||
| 23714.6 | 4 290 ₽ | ||
| 237-146 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Screw clamp connection |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | IN |
| Габариты: глубина | 9 mm / 0.354 inch |
| Fine-stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| GTIN | 4045454539979 |
| Height from the surface | 11 mm / 0.433 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 10/10.16 mm / 0.394/0.4 inch |
| Rated current | 16 A |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated voltage (III / 2) | 800 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solid conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| Strip length | 5 … 7 mm / 0.2 … 0.28 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 3.823 г |
| Ширина | 10 mm / 0.394 inch |
- PCB Interconnect
