Datasheet Wago 250-123/000-006 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 23-полюсный; Зажим Push-in CAGE CLAMP
| 33 предложений от 18 поставщиков Двухступенчатый электрический воздухонагреватель Venttorg NEK 250/12-3 предназначен для подогрева воздушных потоков в круглых воздуховодах приточной вентиляции в производственных помещениях, цехах, гаражах,... | |||
| P25-0123 Harwin | 180 ₽ | ||
| P25-0123 Harwin | 216 ₽ | ||
| P25-0123 Harwin | от 305 ₽ | ||
| P25-0123 Harwin | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | blue |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| GTIN | 4017332328982 |
| Height | 16.7 mm / 0.657 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 23 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 8 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.4 x 0.75 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 23 |
| Total number of potentials | 23 |
| Вес | 1.111 г |
| Ширина | 82 mm / 3.228 inch |
Серия: 250 (100 из 342)
- 250-107/353-604 250-108 250-108/000-005 250-108/000-006 250-108/000-012 250-108/000-014 250-108/353-604 250-109 250-109/000-006 250-109/000-012 250-110 250-110/000-005 250-110/000-006 250-110/000-012 250-111 250-111/000-006 250-111/000-012 250-112 250-112/000-006 250-112/000-012 250-113 250-113/000-006 250-113/000-012 250-114 250-114/000-006 250-114/000-012 250-115 250-115/000-006 250-115/000-012 250-116 250-116/000-006 250-116/000-012 250-117 250-117/000-006 250-117/000-012 250-118 250-118/000-006 250-118/000-012 250-119 250-119/000-006 250-119/000-012 250-120 250-120/000-006 250-120/000-012 250-121 250-121/000-012 250-122 250-122/000-006 250-122/000-012 250-123 250-123/000-006 250-123/000-012 250-124 250-124/000-006 250-124/000-012 250-1402 250-1402/000-012 250-1403 250-1403/000-012 250-1404 250-1404/000-006 250-1404/000-012 250-1405 250-1406 250-1406/000-012 250-1407 250-1408 250-1409 250-1410 250-1410/000-006 250-1410/000-012 250-1411 250-1412 250-1413 250-1414 250-1415 250-1416 250-1416/000-012 250-1417 250-1418 250-1419 250-1420 250-1421 250-1422 250-1423 250-1424 250-202 250-202/000-006 250-202/000-012 250-202/350-604 250-202/353-604 250-202/353-604/997-404 250-203 250-203/000-006 250-203/000-012 250-203/350-604 250-203/353-604 250-203/353-604/997-404 250-204 250-204/000-006
- PCB Interconnect
250123/000006, 250 123/000 006
