Datasheet Wago 250-204/353-604/997-405 — Даташит
Серия250
Модель250-204/353-604/997-405
Клеммная колодка THR PCB; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 4-полюсный; Зажим Push-in CAGE CLAMP; в упаковке в виде ленты и катушки
Actuation typePush-button
Clamping spring materialCopper alloy
Цветblack
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originDE
Габариты: глубина12 mm / 0.472 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Flammability class per UL94V2
GTIN4045454916299
Height15.5 mm / 0.61 inch
Height from the surface13.1 mm / 0.516 inch
Insulating materialPolyamide 46 (PA 46)
Limit temperature range-60 … +115 °C
Material groupIII a
Number of Poles4
Number of connection types1
Number of levels1
PCB contactTHR
Plated through-hole diameter (THR)1 (+ 0.1) мм
Rated current8 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)200 В
Reel diameter of tape-and-reel packaging330 мм
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.4 x 0.75 mm
Solder pin length2.4 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length8.5 … 9.5 mm / 0.33 … 0.37 Inch
Tape width32 мм
Total number of connection points4
Total number of potentials4
Вес2.073 г
Ширина15.5 mm / 0.61 inch
  • PCB Interconnect
250204/353604/997405, 250 204/353 604/997 405
На английском языке: Datasheet Wago 250-204/353-604/997-405
