Datasheet Wago 250-212 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 12-полюсный; Зажим Push-in CAGE CLAMP
|  Купить 250-212 на РадиоЛоцман.Цены — от 54 до 4 674 ₽ 31 предложений от 20 поставщиков Клеммная колодка типа провод к плате, 3.5 мм, 12 вывод(-ов), 24 AWG, 16 AWG, 1.5 мм², Вставной | |||
| 250-212 Wago | от 509 ₽ | ||
| M39006/25-0212 Vishay | 4 674 ₽ | ||
| 250-21/2W-1% CTS Electronic Components | по запросу | ||
| R01-24-250212 | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Copper alloy |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CH |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.126 MJ |
| GTIN | 4044918648820 |
| Height | 16.7 mm / 0.657 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 8 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.4 x 0.75 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Вес | 5.817 г |
| Ширина | 43.5 mm / 1.713 inch |
Серия: 250 (100 из 342)
- 250-202/350-604 250-202/353-604 250-202/353-604/997-404 250-203 250-203/000-006 250-203/000-012 250-203/350-604 250-203/353-604 250-203/353-604/997-404 250-204 250-204/000-006 250-204/000-009 250-204/000-012 250-204/350-604 250-204/353-604 250-204/353-604/997-405 250-205 250-205/000-006 250-205/000-012 250-205/000-024 250-205/350-604 250-205/353-604 250-205/353-604/997-405 250-206 250-206/000-006 250-206/000-012 250-206/350-604 250-206/353-604 250-206/353-604/997-406 250-207 250-207/000-006 250-207/000-012 250-207/350-604 250-207/353-604 250-207/353-604/997-406 250-208 250-208/000-006 250-208/000-012 250-208/350-604 250-208/353-604 250-208/353-604/997-406 250-209 250-209/000-006 250-209/000-012 250-210 250-210/000-006 250-210/000-012 250-211 250-211/000-006 250-211/000-012 250-212 250-212/000-006 250-212/000-012 250-213 250-213/000-006 250-213/000-012 250-214 250-214/000-006 250-214/000-012 250-215 250-215/000-006 250-215/000-012 250-216 250-216/000-006 250-216/000-012 250-217 250-217/000-012 250-218 250-218/000-006 250-218/000-012 250-219 250-219/000-006 250-220 250-220/000-012 250-221 250-222 250-223 250-224 250-224/000-006 250-224/000-012 250-302 250-303 250-304 250-305 250-306 250-307 250-308 250-309 250-310 250-311 250-312 250-313 250-314 250-315 250-316 250-317 250-318 250-319 250-320 250-321
- PCB Interconnect
