Datasheet Wago 250-214 — Даташит
Серия250
Модель250-214
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 14-полюсный; Зажим Push-in CAGE CLAMP
14 предложений от 14 поставщиков
Предохранители, PTC Resettable Fuse 2.5A(hold) 5A(trip) 60V 40A 2.5W 15.6s 0.05Ω Radial 21.3 X 3.1mm T/R Automotive
Hi-Tech Circuit Group
M39006/25-0214
MF-RX250-2-14
BNSMF-RX250-2-14
Actuation typePush-button
Clamping spring materialCopper alloy
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originCH
Габариты: глубина12 mm / 0.472 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.146 MJ
GTIN4044918648851
Height16.7 mm / 0.657 inch
Height from the surface13.1 mm / 0.516 inch
Material groupI
Number of Poles14
Number of connection types1
Number of levels1
PCB contactTHT
Rated current8 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.4 x 0.75 mm
Solder pin length3.6 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length8.5 … 9.5 mm / 0.33 … 0.37 Inch
Total number of connection points14
Total number of potentials14
Вес6.755 г
Ширина50.5 mm / 1.988 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 250-214
