Datasheet Wago 250-215/000-012 — Даташит
Серия250
Модель250-215/000-012
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 15-полюсный; Зажим Push-in CAGE CLAMP
Actuation typePush-button
Clamping spring materialCopper alloy
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originCH
Габариты: глубина12 mm / 0.472 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.141 MJ
GTIN4044918648875
Height16.7 mm / 0.657 inch
Height from the surface13.1 mm / 0.516 inch
Material groupI
Number of Poles15
Number of connection types1
Number of levels1
PCB contactTHT
Rated current8 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.4 x 0.75 mm
Solder pin length3.6 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length8.5 … 9.5 mm / 0.33 … 0.37 Inch
Total number of connection points15
Total number of potentials15
Вес7.136 г
Ширина54 mm / 2.126 inch
  • PCB Interconnect
250215/000012, 250 215/000 012
На английском языке: Datasheet Wago 250-215/000-012
