Datasheet Wago 250-303 — Даташит
клеммная колодка для печатной платы; Нажать кнопку; 0,5 мм²; Расстояние между контактами 2,5 мм; 3-полюсный; Вставной ЗАЖИМ CAGE
|  Купить 250-303 на РадиоЛоцман.Цены — от 559 до 3 436 ₽ 36 предложений от 19 поставщиков Гнездо; цилиндрические предохранители; DIN; 30А; 250В; Полюсы: 3 | |||
| H25030-3S Cooper Bussmann | 1 353 ₽ | ||
| LFH250303S | 1 536 ₽ | ||
| LFH250303S Littelfuse | от 3 306 ₽ | ||
| LR25030-3 Littelfuse | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Copper alloy |
| Цвет | gray |
| Conductor diameter | 0.4 … 0.8 mm |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 0.5 mm² / 24 … 20 AWG |
| Fire load | 0.027 MJ |
| GTIN | 4050821573098 |
| Height | 16.7 mm / 0.657 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 2.5 mm (0.098 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 4 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 100 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.4 x 0.75 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.14 … 0.5 mm² / 24 … 20 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 1.206 г |
| Ширина | 9 mm / 0.354 inch |
Серия: 250 (100 из 342)
- 250-207/000-012 250-207/350-604 250-207/353-604 250-207/353-604/997-406 250-208 250-208/000-006 250-208/000-012 250-208/350-604 250-208/353-604 250-208/353-604/997-406 250-209 250-209/000-006 250-209/000-012 250-210 250-210/000-006 250-210/000-012 250-211 250-211/000-006 250-211/000-012 250-212 250-212/000-006 250-212/000-012 250-213 250-213/000-006 250-213/000-012 250-214 250-214/000-006 250-214/000-012 250-215 250-215/000-006 250-215/000-012 250-216 250-216/000-006 250-216/000-012 250-217 250-217/000-012 250-218 250-218/000-006 250-218/000-012 250-219 250-219/000-006 250-220 250-220/000-012 250-221 250-222 250-223 250-224 250-224/000-006 250-224/000-012 250-302 250-303 250-304 250-305 250-306 250-307 250-308 250-309 250-310 250-311 250-312 250-313 250-314 250-315 250-316 250-317 250-318 250-319 250-320 250-321 250-322 250-323 250-324 250-402 250-402/000-006 250-402/000-012 250-402/350-604 250-403 250-403/000-006 250-403/000-012 250-403/350-604 250-404 250-404/000-006 250-404/000-012 250-404/000-050 250-404/350-604 250-405 250-405/000-006 250-405/000-012 250-405/350-604 250-406 250-406/000-006 250-406/000-012 250-406/350-604 250-407 250-407/000-012 250-407/350-604 250-408 250-408/000-006 250-408/000-012 250-408/350-604
- PCB Interconnect
