Datasheet Wago 250-403/350-604 — Даташит
Клеммная колодка THR PCB; Кнопка; 0,5 мм²; Шаг контактов 2,5 мм; 3-полюсный; Вставной зажим CAGE CLAMP
|  Купить 250-403 на РадиоЛоцман.Цены — от 31 до 7 747 ₽ 15 предложений от 8 поставщиков Жало; изогнутый конус; 1мм; longlife; к паяльной станции | |||
| 250-403 Wago | 31 ₽ | ||
| C250403 | от 7 747 ₽ | ||
| 250-403 Wago | по запросу | ||
| MS25040-3 Diotec | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Copper alloy |
| Цвет | black |
| Conductor diameter | 0.4 … 0.8 mm |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CH |
| Габариты: глубина | 12 mm / 0.472 inch |
| Fine-stranded conductor | 0.2 … 0.5 mm² / 24 … 20 AWG |
| Fire load | 0.027 MJ |
| Flammability class per UL94 | V2 |
| GTIN | 4044918642842 |
| Height | 16.7 mm / 0.657 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Insulating material | Polyamide 46 (PA 46) |
| Limit temperature range | -60 … +115 °C |
| Material group | III a |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Pin spacing | 2.5 mm (0.098 inch) |
| Plated through-hole diameter (THR) | 1 (+ 0.1) мм |
| Product Group | 4 (Printed Circuit) |
| Rated current | 4 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.4 x 0.75 mm |
| Solder pin length | 2.4 мм |
| Solid conductor | 0.14 … 0.5 mm² / 24 … 20 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 1.314 г |
| Ширина | 9 mm / 0.354 inch |
Серия: 250 (100 из 342)
- 250-215/000-006 250-215/000-012 250-216 250-216/000-006 250-216/000-012 250-217 250-217/000-012 250-218 250-218/000-006 250-218/000-012 250-219 250-219/000-006 250-220 250-220/000-012 250-221 250-222 250-223 250-224 250-224/000-006 250-224/000-012 250-302 250-303 250-304 250-305 250-306 250-307 250-308 250-309 250-310 250-311 250-312 250-313 250-314 250-315 250-316 250-317 250-318 250-319 250-320 250-321 250-322 250-323 250-324 250-402 250-402/000-006 250-402/000-012 250-402/350-604 250-403 250-403/000-006 250-403/000-012 250-403/350-604 250-404 250-404/000-006 250-404/000-012 250-404/000-050 250-404/350-604 250-405 250-405/000-006 250-405/000-012 250-405/350-604 250-406 250-406/000-006 250-406/000-012 250-406/350-604 250-407 250-407/000-012 250-407/350-604 250-408 250-408/000-006 250-408/000-012 250-408/350-604 250-409 250-409/000-006 250-409/000-012 250-410 250-410/000-006 250-410/000-012 250-411 250-411/000-006 250-411/000-009 250-412 250-412/000-006 250-412/000-012 250-413 250-414 250-415 250-416 250-416/000-006 250-416/000-012 250-417 250-418 250-418/000-006 250-418/000-012 250-419 250-420 250-420/000-006 250-420/000-012 250-421 250-422 250-422/000-006
- PCB Interconnect
250403/350604, 250 403/350 604
