Datasheet Wago 250-604 — Даташит
Серия250
Модель250-604
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 7,5 мм; 4-полюсный; Зажим Push-in CAGE CLAMP
EUROMAG EM2506 SERIES 04 POLE / 4 Position Wire to Board Terminal Block Horizontal with Board 0.300 (7.62mm) Through Hole
25-060-4X
TE Connectivity
83 357 ₽
25-060-4X
ТаймЧипс
25-060-4X
TE Connectivity
EM250604
Eaton
Actuation typePush-button
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина13 mm / 0.512 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor0.75 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1 mm²
Fire load0.115 MJ
GTIN4044918304177
Height20.5 mm / 0.807 inch
Height from the surface16.5 mm / 0.65 inch
Material groupI
Number of Poles4
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current17.5 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 1.5 mm² / 20 … 14 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points4
Total number of potentials4
Вес4.894 г
Ширина29 mm / 1.142 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 250-604
