Datasheet Wago 250-607 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 7,5 мм; 7-полюсный; Зажим Push-in CAGE CLAMP
![]() 8 предложений от 8 поставщиков Реле Мощности, Electromechanical Relay SPST-NO/SPST-NC 5A 120VAC Flange Mount | |||
Ключ гаечный рожковый Jonnesway W250607 Jonnesway | 248 ₽ | ||
250-607 Wago | по запросу | ||
AAT2506_07 | по запросу | ||
FN250607 | по запросу |
Actuation type | Push-button |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 13 mm / 0.512 inch |
Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
Fine-stranded conductor | 0.75 … 1.5 mm² / 18 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1 mm² |
Fire load | 0.202 MJ |
GTIN | 4044918304207 |
Height | 20.5 mm / 0.807 inch |
Height from the surface | 16.5 mm / 0.65 inch |
Material group | I |
Number of Poles | 7 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 4 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 14 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 7 |
Total number of potentials | 7 |
Вес | 8.575 г |
Ширина | 51.5 mm / 2.028 inch |
Серия: 250 (100 из 342)
- 250-409 250-409/000-006 250-409/000-012 250-410 250-410/000-006 250-410/000-012 250-411 250-411/000-006 250-411/000-009 250-412 250-412/000-006 250-412/000-012 250-413 250-414 250-415 250-416 250-416/000-006 250-416/000-012 250-417 250-418 250-418/000-006 250-418/000-012 250-419 250-420 250-420/000-006 250-420/000-012 250-421 250-422 250-422/000-006 250-422/000-012 250-423 250-424 250-424/000-006 250-424/000-012 250-502 250-502/000-006 250-502/000-012 250-503 250-503/000-006 250-503/000-012 250-504 250-504/000-006 250-504/000-012 250-505 250-505/000-006 250-505/000-012 250-506 250-506/000-006 250-506/000-012 250-507 250-508 250-508/000-012 250-509 250-510 250-510/000-012 250-511 250-512 250-512/000-006 250-512/000-012 250-513 250-514 250-515 250-516 250-518/000-012 250-602 250-602/000-006 250-602/000-012 250-603 250-603/000-006 250-604 250-604/000-006 250-604/000-012 250-605 250-605/000-006 250-605/000-012 250-606 250-607 250-608 250-609 250-610 250-611 250-612 250-702 250-702/000-006 250-702/000-012 250-703 250-704 250-704/000-012 250-705 250-706 250-706/000-006 250-706/000-012 250-707 250-708 250-709 250-710 250-712 250-712/000-012 250-716 250-724
- PCB Interconnect
