Datasheet Wago 250-610 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 7,5 мм; 10-полюсный; Зажим Push-in CAGE CLAMP
Купить 250-610 на РадиоЛоцман.Цены — от 3 240 до 34 460 ₽9 предложений от 9 поставщиков Ввод кабельный латунный IP 68 M40 (упак.5шт) | |||
| 250610 | 32 010 ₽ | ||
| 250610 | 34 460 ₽ | ||
| EM250610 | по запросу | ||
| 250-610BK*2 CTS Electronic Components | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13 mm / 0.512 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.75 … 1.5 mm² / 18 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1 mm² |
| Fire load | 0.289 MJ |
| GTIN | 4044918304238 |
| Height | 20.5 mm / 0.807 inch |
| Height from the surface | 16.5 mm / 0.65 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 14 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 12.256 г |
| Ширина | 74 mm / 2.913 inch |
Серия: 250 (100 из 342)
- 250-409 250-409/000-006 250-409/000-012 250-410 250-410/000-006 250-410/000-012 250-411 250-411/000-006 250-411/000-009 250-412 250-412/000-006 250-412/000-012 250-413 250-414 250-415 250-416 250-416/000-006 250-416/000-012 250-417 250-418 250-418/000-006 250-418/000-012 250-419 250-420 250-420/000-006 250-420/000-012 250-421 250-422 250-422/000-006 250-422/000-012 250-423 250-424 250-424/000-006 250-424/000-012 250-502 250-502/000-006 250-502/000-012 250-503 250-503/000-006 250-503/000-012 250-504 250-504/000-006 250-504/000-012 250-505 250-505/000-006 250-505/000-012 250-506 250-506/000-006 250-506/000-012 250-507 250-508 250-508/000-012 250-509 250-510 250-510/000-012 250-511 250-512 250-512/000-006 250-512/000-012 250-513 250-514 250-515 250-516 250-518/000-012 250-602 250-602/000-006 250-602/000-012 250-603 250-603/000-006 250-604 250-604/000-006 250-604/000-012 250-605 250-605/000-006 250-605/000-012 250-606 250-607 250-608 250-609 250-610 250-611 250-612 250-702 250-702/000-006 250-702/000-012 250-703 250-704 250-704/000-012 250-705 250-706 250-706/000-006 250-706/000-012 250-707 250-708 250-709 250-710 250-712 250-712/000-012 250-716 250-724
- PCB Interconnect
