Datasheet Wago 250-703 — Даташит
Двухуровневая клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 5 мм; 2 x 3-полюсный; Зажим Push-in CAGE CLAMP
5 предложений от 5 поставщиков Commercial Composition 9mm Diameter Variable Resistors | |||
| 250-703 Wago | 197 ₽ | ||
| EM250703 | по запросу | ||
| B250703 | по запросу | ||
| 250-703 CTS Electronic Components | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 21.7 mm / 0.854 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.75 … 1.5 mm² / … |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1 mm² |
| Fire load | 0.127 MJ |
| GTIN | 4044918300896 |
| Height | 24.9 mm / 0.98 inch |
| Height from the surface | 20.9 mm / 0.823 inch |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Вес | 5.91 г |
| Ширина | 16.2 mm / 0.638 inch |
Серия: 250 (100 из 342)
- 250-409 250-409/000-006 250-409/000-012 250-410 250-410/000-006 250-410/000-012 250-411 250-411/000-006 250-411/000-009 250-412 250-412/000-006 250-412/000-012 250-413 250-414 250-415 250-416 250-416/000-006 250-416/000-012 250-417 250-418 250-418/000-006 250-418/000-012 250-419 250-420 250-420/000-006 250-420/000-012 250-421 250-422 250-422/000-006 250-422/000-012 250-423 250-424 250-424/000-006 250-424/000-012 250-502 250-502/000-006 250-502/000-012 250-503 250-503/000-006 250-503/000-012 250-504 250-504/000-006 250-504/000-012 250-505 250-505/000-006 250-505/000-012 250-506 250-506/000-006 250-506/000-012 250-507 250-508 250-508/000-012 250-509 250-510 250-510/000-012 250-511 250-512 250-512/000-006 250-512/000-012 250-513 250-514 250-515 250-516 250-518/000-012 250-602 250-602/000-006 250-602/000-012 250-603 250-603/000-006 250-604 250-604/000-006 250-604/000-012 250-605 250-605/000-006 250-605/000-012 250-606 250-607 250-608 250-609 250-610 250-611 250-612 250-702 250-702/000-006 250-702/000-012 250-703 250-704 250-704/000-012 250-705 250-706 250-706/000-006 250-706/000-012 250-707 250-708 250-709 250-710 250-712 250-712/000-012 250-716 250-724
- PCB Interconnect
