Datasheet Wago 250-707 — Даташит
Серия250
Модель250-707
Двухуровневая клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 5 мм; 2 x 7-полюсный; Зажим Push-in CAGE CLAMP
Integrated USB 2.0 Compatible 7-Port Hub
EM250707
EM250707
Eaton
TradeElectronics
USB2507_07
LifeElectronics
Actuation typePush-button
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originCH
Габариты: глубина21.7 mm / 0.854 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor0.75 … 1.5 mm² / …
Fine-stranded conductor with ferrule with plastic collar0.5 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1 mm²
Fire load0.287 MJ
GTIN4044918304504
Height24.9 mm / 0.98 inch
Height from the surface20.9 mm / 0.823 inch
Number of Poles7
Number of connection types1
Number of levels2
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current10 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)400 В
Rated voltage (III / 3)320 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points7
Total number of potentials14
Вес13.531 г
Ширина36.2 mm / 1.425 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 250-707
