Datasheet Wago 250-1414 — Даташит
Клеммная колодка для печатной платы; Кнопка; 0,5 мм²; Шаг контактов 2,54 мм; 14-полюсный; Вставной зажим CAGE CLAMP
2501414 GED0100110S Ключ искробезопасный накидной ударный 12-тигранный 110 mm GEDORE | |||
| 2501414 GEDORE | 154 157 ₽ | ||
| 250-1414 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Copper alloy |
| Цвет | gray |
| Conductor diameter | 0.4 … 0.8 mm |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CH |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 0.5 mm² / 24 … 20 AWG |
| Fire load | 0.104 MJ |
| GTIN | 4044918643344 |
| Height | 16.7 mm / 0.657 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 14 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 2.54 mm (0.1 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 4 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.4 x 0.75 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.14 … 0.5 mm² / 24 … 20 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 14 |
| Total number of potentials | 14 |
| Вес | 5.066 г |
| Ширина | 37.06 mm / 1.459 inch |
Серия: 250 (100 из 342)
- 250-114/000-006 250-114/000-012 250-115 250-115/000-006 250-115/000-012 250-116 250-116/000-006 250-116/000-012 250-117 250-117/000-006 250-117/000-012 250-118 250-118/000-006 250-118/000-012 250-119 250-119/000-006 250-119/000-012 250-120 250-120/000-006 250-120/000-012 250-121 250-121/000-012 250-122 250-122/000-006 250-122/000-012 250-123 250-123/000-006 250-123/000-012 250-124 250-124/000-006 250-124/000-012 250-1402 250-1402/000-012 250-1403 250-1403/000-012 250-1404 250-1404/000-006 250-1404/000-012 250-1405 250-1406 250-1406/000-012 250-1407 250-1408 250-1409 250-1410 250-1410/000-006 250-1410/000-012 250-1411 250-1412 250-1413 250-1414 250-1415 250-1416 250-1416/000-012 250-1417 250-1418 250-1419 250-1420 250-1421 250-1422 250-1423 250-1424 250-202 250-202/000-006 250-202/000-012 250-202/350-604 250-202/353-604 250-202/353-604/997-404 250-203 250-203/000-006 250-203/000-012 250-203/350-604 250-203/353-604 250-203/353-604/997-404 250-204 250-204/000-006 250-204/000-009 250-204/000-012 250-204/350-604 250-204/353-604 250-204/353-604/997-405 250-205 250-205/000-006 250-205/000-012 250-205/000-024 250-205/350-604 250-205/353-604 250-205/353-604/997-405 250-206 250-206/000-006 250-206/000-012 250-206/350-604 250-206/353-604 250-206/353-604/997-406 250-207 250-207/000-006 250-207/000-012 250-207/350-604 250-207/353-604 250-207/353-604/997-406
- PCB Interconnect
2501414, 250 1414
