Datasheet Wago 251-102 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 2-полюсный; ВСТАВЬТЕ ПРОВОД И УСТАНОВИТЕ ЗАЖИМ
12 предложений от 12 поставщиков Банановые Штекеры/Розетки, ABBATRON HH SMITH 251-102 Banana Test Connector, Jack, Cable Mount, 15A, 1kV, Nickel Plated Contacts, Red | |||
| DK-2511-02 | 1 168 ₽ | ||
| 251-102 | 1 367 ₽ | ||
| 2.51102E+12 | по запросу | ||
| DK-2511-02 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | weiß |
| Connection technology | PUSH WIRE® |
| Connection technology 2 | IDC connection |
| Contact material | Copper alloy |
| Country of origin | PL |
| Габариты: глубина | 13.2 mm / 0.52 inch |
| Design | High Version |
| Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
| Fine-stranded conductor (2) | 0.75 mm² / 18 AWG |
| Height | 22.8 mm / 0.898 inch |
| Height from the surface | 19.2 mm / 0.756 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 2 |
| Number of connection points | 1 |
| Number of connection points (connection type) | 1 |
| Number of connection types | 2 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 2 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 3.5 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Solid conductor (2) | 0.5 mm² / 20 AWG |
| Strip length | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
| Strip length (2) | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 2 |
| Ширина | 7.9 mm / 0.311 inch |
Серия: 251 (12)
- PCB Interconnect
