Datasheet Wago 251 — Даташит
| Производитель | Wago |
| Серия | 251 |
12 предложений от 12 поставщиков Банановые Штекеры/Розетки, ABBATRON HH SMITH 251-102 Banana Test Connector, Jack, Cable Mount, 15A, 1kV, Nickel Plated Contacts, Red | |||
| DK-2511-02 | 1 156 ₽ | ||
| 2.51102E+12 | по запросу | ||
| 2.51102e+006 | по запросу | ||
| 760-2511-02 | по запросу | ||
| Parameters / Models | 251-102![]() | 251-103![]() | 251-104![]() | 251-105![]() | 251-106![]() | 251-107![]() | 251-303![]() | 251-304![]() | 251-306![]() | 251-307![]() | 251-308![]() | 251-310![]() |
| Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool |
| Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) |
| Цвет | weiß | weiß | weiß | weiß | weiß | weiß | white | white | white | white | white | white |
| Connection technology | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® |
| Connection technology 2 | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection | IDC connection |
| Contact material | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy |
| Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated |
| Country of origin | PL | PL | PL | PL | PL | PL | CH | CH | CH | CH | CH | CH |
| Габариты: глубина | 13.2 mm / 0.52 inch | 13.2 mm / 0.52 inch | 13.2 mm / 0.52 inch | 13.2 mm / 0.52 inch | 13.2 mm / 0.52 inch | 13.2 mm / 0.52 inch | 13.3 mm / 0.524 inch | 13.3 mm / 0.524 inch | 13.3 mm / 0.524 inch | 13.3 mm / 0.524 inch | 13.3 mm / 0.524 inch | 13.3 mm / 0.524 inch |
| Design | High Version | High Version | High Version | High Version | High Version | High Version | Low Version | Low Version | Low Version | Low Version | Low Version | Low Version |
| Drilled hole diameter (tolerance), мм | 1.2(+ 0.1) | 1.2(+ 0.1) | 1.2(+ 0.1) | 1.2(+ 0.1) | 1.2(+ 0.1) | 1.2(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) |
| Fine-stranded conductor (2) | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG |
| Fire load, MJ | 0.025 | 0.033 | 0.048 | 0.054 | 0.062 | 0.077 | ||||||
| Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 |
| GTIN | 4044918836425 | 4044918836449 | 4044918836456 | 4044918836463 | 4044918836487 | 4044918836494 | ||||||
| Height | 22.8 mm / 0.898 inch | 22.8 mm / 0.898 inch | 22.8 mm / 0.898 inch | 22.8 mm / 0.898 inch | 22.8 mm / 0.898 inch | 22.8 mm / 0.898 inch | 15.5 mm / 0.61 inch | 15.5 mm / 0.61 inch | 15.5 mm / 0.61 inch | 15.5 mm / 0.61 inch | 15.5 mm / 0.61 inch | 15.5 mm / 0.61 inch |
| Height from the surface | 19.2 mm / 0.756 inch | 19.2 mm / 0.756 inch | 19.2 mm / 0.756 inch | 19.2 mm / 0.756 inch | 19.2 mm / 0.756 inch | 19.2 mm / 0.756 inch | 12.3 mm / 0.484 inch | 12.3 mm / 0.484 inch | 12.3 mm / 0.484 inch | 12.3 mm / 0.484 inch | 12.3 mm / 0.484 inch | 12.3 mm / 0.484 inch |
| Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
| Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 |
| Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C |
| Material group | I | I | I | I | I | I | I | I | I | I | I | I |
| Number of Poles | 2 | 3 | 4 | 5 | 6 | 7 | 3 | 4 | 6 | 7 | 8 | 10 |
| Number of connection points | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of connection points (connection type) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of connection types | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| Number of levels | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| Number of solder pins per potential | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT |
| Pin spacing | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) |
| Product Group | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) |
| Rated current, A | 2 | 2 | 2 | 2 | 2 | 2 | 6 | 6 | 6 | 6 | 6 | 6 |
| Rated impulse voltage (II / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Rated impulse voltage (III / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Rated voltage (II / 2), В | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 |
| Rated voltage (III / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 |
| Rated voltage (III / 3), В | 250 | 250 | 250 | 250 | 250 | 250 | 320 | 320 | 320 | 320 | 320 | 320 |
| Solder pin arrangement | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm | 0.5 x 0.75 mm |
| Solder pin length, мм | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.2 | 3.2 | 3.2 | 3.2 | 3.2 | 3.2 |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1 mm² / 20 … 18 AWG | 0.5 … 1 mm² / 20 … 18 AWG | 0.5 … 1 mm² / 20 … 18 AWG | 0.5 … 1 mm² / 20 … 18 AWG | 0.5 … 1 mm² / 20 … 18 AWG | 0.5 … 1 mm² / 20 … 18 AWG |
| Solid conductor (2) | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG | 0.5 mm² / 20 AWG |
| Strip length | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch |
| Strip length (2) | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
| Total number of connection points | 4 | 6 | 8 | 10 | 12 | 14 | 3 | 4 | 6 | 7 | 8 | 10 |
| Total number of potentials | 2 | 3 | 4 | 5 | 6 | 7 | 3 | 4 | 6 | 7 | 8 | 10 |
| Вес, г | 1.27 | 1.661 | 2.435 | 2.797 | 3.205 | 3.974 | ||||||
| Ширина | 7.9 mm / 0.311 inch | 11.4 mm / 0.449 inch | 14.9 mm / 0.587 inch | 18.4 mm / 0.724 inch | 21.9 mm / 0.862 inch | 25.4 mm / 1 inch | 11.4 mm / 0.449 inch | 14.9 mm / 0.587 inch | 21.9 mm / 0.862 inch | 25.4 mm / 1 inch | 28.9 mm / 1.138 inch | 35.9 mm / 1.413 inch |
Серия: 251 (12)
- PCB Interconnect
