Datasheet Wago 251-103 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 3-полюсный; ВСТАВЬТЕ ПРОВОД И УСТАНОВИТЕ ЗАЖИМ
![]() 8 предложений от 8 поставщиков Банановые Штекеры/Розетки, ABBATRON HH SMITH 251-103 Banana Test Connector, Jack, Cable Mount, 15A, 1kV, Nickel Plated Contacts, Black | |||
251-103 | 242 ₽ | ||
DK-2511-03 | 1 302 ₽ | ||
251-103 | 1 372 ₽ | ||
15-25-1103 Molex | по запросу |
Цвет | weiß |
Connection technology | PUSH WIRE® |
Connection technology 2 | IDC connection |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 13.2 mm / 0.52 inch |
Design | High Version |
Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
Fine-stranded conductor (2) | 0.75 mm² / 18 AWG |
Height | 22.8 mm / 0.898 inch |
Height from the surface | 19.2 mm / 0.756 inch |
Material group | I |
Number of Poles | 3 |
Number of connection points | 1 |
Number of connection points (connection type) | 1 |
Number of connection types | 2 |
Number of levels | 2 |
PCB contact | THT |
Rated current | 2 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 3.5 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Solid conductor (2) | 0.5 mm² / 20 AWG |
Strip length | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
Strip length (2) | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
Total number of connection points | 6 |
Total number of potentials | 3 |
Ширина | 11.4 mm / 0.449 inch |
Серия: 251 (12)
- PCB Interconnect
