Datasheet Wago 251-106 — Даташит
Серия251
Модель251-106
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 6-полюсный; НАЖИМНОЙ ПРОВОД & УСТАНОВОЧНЫЙ ЗАЖИМ
Actuation typeOperating tool
Цветweiß
Connection technologyPUSH WIRE®
Connection technology 2IDC connection
Contact materialCopper alloy
Contact platingtin-plated
Country of originPL
Габариты: глубина13.2 mm / 0.52 inch
DesignHigh Version
Drilled hole diameter (tolerance)1.2(+ 0.1) мм
Fine-stranded conductor (2)0.75 mm² / 18 AWG
Height22.8 mm / 0.898 inch
Height from the surface19.2 mm / 0.756 inch
Material groupI
Number of Poles6
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels2
PCB contactTHT
Rated current2 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.75 mm
Solder pin length3.5 мм
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG
Solid conductor (2)0.5 mm² / 20 AWG
Strip length7.5 … 8.5 mm / 0.3 … 0.33 Inch
Strip length (2)7.5 … 8.5 mm / 0.3 … 0.33 Inch
Total number of connection points12
Total number of potentials6
Ширина21.9 mm / 0.862 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 251-106
