Datasheet Wago 251-304 — Даташит
Клеммная колодка для печатной платы; 1 мм²; Шаг контактов 3,5 мм; 4-полюсный; НАЖИМНОЙ ПРОВОД & УСТАНОВОЧНЫЙ ЗАЖИМ
![]() 8 предложений от 5 поставщиков Штангенциркуль; Дл: 200мм | |||
251.304 | от 10 020 ₽ | ||
251.304 | от 10 978 ₽ | ||
2.51304e+009 | по запросу | ||
HA2-5130-4 | по запросу |
Цвет | white |
Connection technology | PUSH WIRE® |
Connection technology 2 | IDC connection |
Contact material | Copper alloy |
Country of origin | CH |
Габариты: глубина | 13.3 mm / 0.524 inch |
Design | Low Version |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor (2) | 0.75 mm² / 18 AWG |
Fire load | 0.033 MJ |
GTIN | 4044918836449 |
Height | 15.5 mm / 0.61 inch |
Height from the surface | 12.3 mm / 0.484 inch |
Material group | I |
Number of Poles | 4 |
Number of connection points | 1 |
Number of connection points (connection type) | 1 |
Number of connection types | 2 |
Number of levels | 2 |
PCB contact | THT |
Rated current | 6 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 3.2 мм |
Solid conductor | 0.5 … 1 mm² / 20 … 18 AWG |
Solid conductor (2) | 0.5 mm² / 20 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Strip length (2) | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Вес | 1.661 г |
Ширина | 14.9 mm / 0.587 inch |
Серия: 251 (12)
- PCB Interconnect
