Datasheet Wago 251-306 — Даташит
Клеммная колодка для печатной платы; 1 мм²; Шаг контактов 3,5 мм; 6-полюсный; ПРОВОД НАЖИМАЕТСЯ И ЗАЖИМ УСТАНАВЛИВАЕТСЯ
251-306, COMBI PCB Клеммный блок 6-полюсный | |||
| 251-306 Wago Оф. дистрибьютор | 224 ₽ | ||
| 251306 | по запросу | ||
| 2.51306e+011 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | white |
| Connection technology | PUSH WIRE® |
| Connection technology 2 | IDC connection |
| Contact material | Copper alloy |
| Country of origin | CH |
| Габариты: глубина | 13.3 mm / 0.524 inch |
| Design | Low Version |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor (2) | 0.75 mm² / 18 AWG |
| Fire load | 0.048 MJ |
| GTIN | 4044918836456 |
| Height | 15.5 mm / 0.61 inch |
| Height from the surface | 12.3 mm / 0.484 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 6 |
| Number of connection points | 1 |
| Number of connection points (connection type) | 1 |
| Number of connection types | 2 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 3.2 мм |
| Solid conductor | 0.5 … 1 mm² / 20 … 18 AWG |
| Solid conductor (2) | 0.5 mm² / 20 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Strip length (2) | 7.5 … 8.5 mm / 0.3 … 0.33 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Вес | 2.435 г |
| Ширина | 21.9 mm / 0.862 inch |
Серия: 251 (12)
- PCB Interconnect
Купить 251-306 на РадиоЛоцман.Цены
