Datasheet Wago 251-307 — Даташит
Серия251
Модель251-307
Клеммная колодка для печатной платы; 1 мм²; Шаг контактов 3,5 мм; 7-полюсный; НАЖИМНОЙ ПРОВОД & УСТАНОВОЧНЫЙ ЗАЖИМ
LifeElectronics
HA2-5130-7по запросу
Actuation typeOperating tool
Цветwhite
Connection technologyPUSH WIRE®
Connection technology 2IDC connection
Contact materialCopper alloy
Contact platingtin-plated
Country of originCH
Габариты: глубина13.3 mm / 0.524 inch
DesignLow Version
Fine-stranded conductor (2)0.75 mm² / 18 AWG
Fire load0.054 MJ
GTIN4044918836463
Height15.5 mm / 0.61 inch
Height from the surface12.3 mm / 0.484 inch
Material groupI
Number of Poles7
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels2
PCB contactTHT
Rated current6 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.75 mm
Solder pin length3.2 мм
Solid conductor0.5 … 1 mm² / 20 … 18 AWG
Solid conductor (2)0.5 mm² / 20 AWG
Strip length (2)7.5 … 8.5 mm / 0.3 … 0.33 Inch
Total number of connection points7
Total number of potentials7
Вес2.797 г
Ширина25.4 mm / 1 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 251-307
