Datasheet Wago 253-108 — Даташит
Клеммная колодка для печатной платы с 2 проводниками; 1,5 мм²; Шаг контактов 5 мм; 8-полюсный; PUSH WIRE
| Купить 253-108 на РадиоЛоцман.Цены — от 242 до 11 095 ₽ 6 предложений от 6 поставщиков 0.4-?© Low-Voltage Dual SPDT Analog Switch | |||
| 253-108 Wago | 242 ₽ | ||
| T-2-53108-S | 11 095 ₽ | ||
| T253108S STMicroelectronics | по запросу | ||
| 25-3108SQ.OHMTYPE | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB 2 | 90 ° |
| Connection technology | PUSH WIRE® |
| Connection technology 2 | PUSH WIRE® |
| Connection type (1) | PUSH WIRE® connection |
| Connection type (2) | PUSH WIRE® connection |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CN |
| Габариты: глубина | 12.8 mm / 0.504 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fire load | 0.146 MJ |
| GTIN | 4044918689496 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 13 mm / 0.512 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Note (strip length) | 7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides) |
| Note (strip length) 2 | 7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides) |
| Number of Poles | 8 |
| Number of connection points | 1 |
| Number of connection points (connection type) | 1 |
| Number of connection types | 2 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.5 x 0.8 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Solid conductor (2) | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Strip length (2) | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
| Total number of connection points | 16 |
| Total number of potentials | 8 |
| Вес | 7.054 г |
| Ширина | 42 mm / 1.654 inch |
Серия: 253 (35)
- 253-102 253-102/000-006 253-102/000-012 253-103 253-103/000-006 253-104 253-104/000-006 253-104/000-012 253-105 253-105/000-006 253-105/000-012 253-106 253-106/000-006 253-106/000-012 253-107 253-107/000-006 253-107/000-012 253-108 253-108/000-006 253-109 253-109/000-006 253-110 253-110/000-006 253-110/000-012 253-111 253-111/000-006 253-112 253-112/000-012 253-113 253-114 253-114/000-006 253-115 253-116 253-116/000-006 253-116/000-012
- PCB Interconnect
