Datasheet Wago 253-114/000-006 — Даташит
Серия253
Модель253-114/000-006
Клеммная колодка для печатной платы с 2 проводниками; 1,5 мм²; Шаг контактов 5 мм; 14-полюсный; PUSH WIRE
LifeElectronics
HDSP253114
2.53114e+006
Actuation typeOperating tool
Цветblue
Conductor entry angle to the PCB 290 °
Connection technologyPUSH WIRE®
Connection technology 2PUSH WIRE®
Connection type (1)PUSH WIRE® connection
Connection type (2)PUSH WIRE® connection
Contact platingtin-plated
Country of originCN
Габариты: глубина12.8 mm / 0.504 inch
Fire load0.248 MJ
GTIN4017332649735
Height16.6 mm / 0.654 inch
Height from the surface13 mm / 0.512 inch
Material groupI
Note (strip length)7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides)
Note (strip length) 27 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides)
Number of Poles14
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels2
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current17.5 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.8 mm
Solder pin length3.6 мм
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG
Solid conductor (2)0.5 … 1.5 mm² / 20 … 16 AWG
Strip length8.5 … 9.5 mm / 0.33 … 0.37 Inch
Strip length (2)8.5 … 9.5 mm / 0.33 … 0.37 Inch
Total number of connection points28
Total number of potentials14
Вес12.052 г
Ширина72 mm / 2.835 inch
  • PCB Interconnect
253114/000006, 253 114/000 006
На английском языке: Datasheet Wago 253-114/000-006
