Datasheet Wago 254-459 — Даташит
Серия254
Модель254-459
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5/5,08 мм; 9-полюсный; PUSH WIRE
Hi-Tech Circuit Group
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Connection technologyPUSH WIRE®
Contact platingtin-plated
Country of originPL
Габариты: глубина13.5 mm / 0.531 inch
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm²
Fire load0.168 MJ
GTIN4044918940672
Height19.7 mm / 0.776 inch
Height from the surface15.7 mm / 0.618 inch
Material groupI
Number of Poles9
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing5/5.08 mm / 0.197/0.2 inch
Rated current24 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 2.5 mm² / 20 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points9
Total number of potentials9
Вес9.636 г
Ширина46.5 mm / 1.831 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 254-459
