Datasheet Wago 254-551 — Даташит
Стекируемый клеммный блок для печатных плат; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 1-полюсный; PUSH WIRE
|  Купить 254-551 на РадиоЛоцман.Цены — от 40 до 3 523 ₽ 6 предложений от 6 поставщиков , Terminal block; 7.5mm; angled 45°; 0.5÷2.5mm²; ways:1; tinned; 24A | |||
| 254-551 Wago | 40 ₽ | ||
| 254551-C4 | 1 235 ₽ | ||
| 254551-C2 | 1 644 ₽ | ||
| 254-551 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | PUSH WIRE® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13.5 mm / 0.531 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1.5 mm² |
| Fire load | 0.024 MJ |
| GTIN | 4044918940832 |
| Height | 19.7 mm / 0.776 inch |
| Height from the surface | 15.7 mm / 0.618 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.5 … 2.5 mm² / 20 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 1.329 г |
| Ширина | 9.2 mm / 0.362 inch |
Серия: 254 (100 из 101)
- 254-100 254-152 254-153 254-154 254-156 254-158 254-162 254-166 254-174 254-186 254-198 254-200 254-252 254-253 254-254 254-256 254-258 254-262 254-266 254-274 254-300 254-352 254-353 254-354 254-356 254-358 254-362 254-366 254-374 254-400 254-451 254-452 254-452/000-017 254-453 254-454 254-455 254-456 254-457 254-458 254-459 254-460 254-462 254-466 254-474 254-551 254-552 254-553 254-554 254-555 254-556 254-557 254-558 254-559 254-560 254-562 254-600 254-651 254-652 254-653 254-654 254-655 254-656 254-657 254-658 254-659 254-660 254-662 254-700 254-801 254-802 254-803 254-804 254-806 254-807 254-811 254-812 254-813 254-814 254-816 254-817 254-821 254-822 254-823 254-824 254-826 254-827 254-842 254-843 254-844 254-846 254-847 254-852 254-853 254-854 254-856 254-857 254-862 254-863 254-864 254-866
- PCB Interconnect
