Datasheet Wago 254-552 — Даташит
Серия254
Модель254-552
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 2-полюсный; ПРОВОД НАЖИМАЕТСЯ
254-552
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Connection technologyPUSH WIRE®
Contact platingtin-plated
Country of originPL
Габариты: глубина13.5 mm / 0.531 inch
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm²
Fire load0.054 MJ
GTIN4044918940849
Height19.7 mm / 0.776 inch
Height from the surface15.7 mm / 0.618 inch
Material groupI
Number of Poles2
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5/7.62 mm / 0.295/0.3 inch
Rated current24 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 2.5 mm² / 20 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points2
Total number of potentials2
Вес2.798 г
Ширина16.5 mm / 0.65 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 254-552
