Datasheet Wago 254-560 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 10-полюсный; ПРОВОД ДЛЯ ПОДКЛЮЧЕНИЯ
![]() 5 предложений от 5 поставщиков , XP POWER ECS25/45/60 COVER Power Supply Accessory, Cover Kit, ECS25, ECS45, ECS60 Series | |||
ECS25/45/60 COVER XP Power | 842 ₽ | ||
ECS25/45/60 COVER XP Power | 966 ₽ | ||
FMCA2545-60 | 20 826 ₽ | ||
254-560 Wago | по запросу |
Цвет | gray |
Connection technology | PUSH WIRE® |
Country of origin | PL |
Габариты: глубина | 13.5 mm / 0.531 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1.5 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1.5 mm² |
Fire load | 0.246 MJ |
GTIN | 4044918940917 |
Height | 19.7 mm / 0.776 inch |
Height from the surface | 15.7 mm / 0.618 inch |
Material group | I |
Number of Poles | 10 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 4 мм |
Solid conductor | 0.5 … 2.5 mm² / 20 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 10 |
Total number of potentials | 10 |
Вес | 13.246 г |
Ширина | 76.5 mm / 3.012 inch |
Серия: 254 (100 из 101)
- 254-152 254-153 254-154 254-156 254-158 254-162 254-166 254-174 254-186 254-198 254-200 254-252 254-253 254-254 254-256 254-258 254-262 254-266 254-274 254-300 254-352 254-353 254-354 254-356 254-358 254-362 254-366 254-374 254-400 254-451 254-452 254-452/000-017 254-453 254-454 254-455 254-456 254-457 254-458 254-459 254-460 254-462 254-466 254-474 254-551 254-552 254-553 254-554 254-555 254-556 254-557 254-558 254-559 254-560 254-562 254-600 254-651 254-652 254-653 254-654 254-655 254-656 254-657 254-658 254-659 254-660 254-662 254-700 254-801 254-802 254-803 254-804 254-806 254-807 254-811 254-812 254-813 254-814 254-816 254-817 254-821 254-822 254-823 254-824 254-826 254-827 254-842 254-843 254-844 254-846 254-847 254-852 254-853 254-854 254-856 254-857 254-862 254-863 254-864 254-866 254-867
- PCB Interconnect
