Datasheet Wago 254-853 — Даташит
Серия254
Модель254-853
Стекируемый клеммный блок для печатных плат; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 1-полюсный; PUSH WIRE
Actuation typeOperating tool
Цветlight gray
Conductor entry angle to the PCB45 °
Connection technologyPUSH WIRE®
Contact platingtin-plated
Country of originPL
Габариты: глубина13.5 mm / 0.531 inch
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm²
Fire load0.025 MJ
GTIN4044918942966
Height19.7 mm / 0.776 inch
Height from the surface15.7 mm / 0.618 inch
Material groupI
Number of Poles1
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5/7.62 mm / 0.295/0.3 inch
Rated current24 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 2.5 mm² / 20 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points1
Total number of potentials1
Вес1.363 г
Ширина9.2 mm / 0.362 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 254-853
