Datasheet Wago 254-867 — Даташит
Серия254
Модель254-867
Стекируемый клеммный блок для печатных плат; 2,5 мм²; Шаг контактов 10/10,16 мм; 1-полюсный; PUSH WIRE
Actuation typeOperating tool
Цветlight green
Conductor entry angle to the PCB45 °
Connection technologyPUSH WIRE®
Contact platingtin-plated
Country of originPL
Габариты: глубина13.5 mm / 0.531 inch
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm²
Fire load0.032 MJ
GTIN4044918943284
Height19.7 mm / 0.776 inch
Height from the surface15.7 mm / 0.618 inch
Material groupI
Number of Poles1
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing10/10.16 mm / 0.394/0.4 inch
Rated current24 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)630 В
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.5 x 0.75 mm
Solder pin length4 мм
Solid conductor0.5 … 2.5 mm² / 20 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points1
Total number of potentials1
Вес1.594 г
Ширина11.7 mm / 0.461 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 254-867
