Datasheet Wago 255-410/333-000 — Даташит
Клеммная колодка для печатной платы; рычаги, управляемые пальцами; 2,5 мм²; Шаг контактов 5/5,08 мм; 10-полюсный; CAGE CLAMP; возможность объединения
| PCB TERMINAL BLOCK; FINGER-OPERA | |||
| 255-410/333-000 Wago | по запросу | ||
| Actuation type | Finger-operated lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 23 mm / 0.906 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.186 MJ |
| GTIN | 4045454525637 |
| Height | 22.2 mm / 0.874 inch |
| Height from the surface | 14.2 mm / 0.559 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 12.39 г |
| Ширина | 52.9 mm / 2.083 inch |
Серия: 255 (100 из 157)
- 255-100 255-200 255-300 255-400 255-401 255-402 255-402/000-009/999-950 255-402/333-000 255-402/333-009/999-950 255-403 255-403/000-009/999-950 255-403/333-000 255-404 255-404/000-009/999-950 255-404/004-012 255-404/333-000 255-405 255-405/000-009/999-950 255-405/333-000 255-406 255-406/000-009/999-950 255-406/333-000 255-407 255-407/000-009/999-950 255-407/333-000 255-408 255-408/000-009/999-950 255-408/333-000 255-409 255-409/000-009/999-950 255-409/333-000 255-410 255-410/000-009/999-950 255-410/333-000 255-412 255-412/000-009/999-950 255-412/333-000 255-416 255-416/000-009/999-950 255-416/333-000 255-420/000-012 255-424 255-424/000-009/999-950 255-436 255-436/000-009/999-950 255-448 255-448/000-009/999-950 255-500 255-501 255-502 255-502/000-009/999-950 255-502/333-000 255-502/333-009/999-950 255-503 255-503/000-009/999-950 255-503/333-000 255-504 255-504/000-009/999-950 255-504/333-000 255-505 255-505/000-009/999-950 255-505/333-000 255-505/333-006 255-506 255-506/000-009/999-950 255-506/333-000 255-506/333-006 255-507 255-507/000-009/999-950 255-507/333-000 255-507/333-006 255-508 255-508/000-009/999-950 255-508/333-000 255-509 255-509/000-009/999-950 255-509/333-000 255-510 255-510/000-009/999-950 255-510/333-000 255-512 255-512/000-009/999-950 255-512/333-000 255-516 255-516/000-009/999-950 255-524 255-524/000-009/999-950 255-524/333-000 255-600 255-601 255-602 255-602/000-009/999-950 255-602/333-000 255-602/333-009/999-950 255-603 255-603/000-009/999-950 255-603/333-000 255-604 255-604/000-009/999-950 255-604/333-000
- PCB Interconnect
255410/333000, 255 410/333 000
