Datasheet Wago 255-508 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 8-полюсный; CAGE CLAMP; возможность объединения
![]() 9 предложений от 8 поставщиков IEC Appliance Inlet C14 with Filter, Fuseholder 2-pole, Line Switch 2-pole | |||
EMKDS2,5/5-5,08 Phoenix Contact | от 1 378 ₽ | ||
255-508/333-000 Wago | по запросу | ||
FKC2.5/5-5.08 | по запросу | ||
FKIC2.5/5-5.08 Schurter | по запросу |
Actuation type | Push-button |
Цвет | gray |
Conductor entry angle to the PCB | 90 ° |
Country of origin | CH |
Габариты: глубина | 18.3 mm / 0.72 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.198 MJ |
GTIN | 4044918661645 |
Height | 18.2 mm / 0.717 inch |
Height from the surface | 14.2 mm / 0.559 inch |
Material group | I |
Number of Poles | 8 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 25 … 12 AWG |
Total number of connection points | 8 |
Total number of potentials | 8 |
Вес | 11.648 г |
Ширина | 42.9 mm / 1.689 inch |
Серия: 255 (100 из 157)
- 255-406/333-000 255-407 255-407/000-009/999-950 255-407/333-000 255-408 255-408/000-009/999-950 255-408/333-000 255-409 255-409/000-009/999-950 255-409/333-000 255-410 255-410/000-009/999-950 255-410/333-000 255-412 255-412/000-009/999-950 255-412/333-000 255-416 255-416/000-009/999-950 255-416/333-000 255-420/000-012 255-424 255-424/000-009/999-950 255-436 255-436/000-009/999-950 255-448 255-448/000-009/999-950 255-500 255-501 255-502 255-502/000-009/999-950 255-502/333-000 255-502/333-009/999-950 255-503 255-503/000-009/999-950 255-503/333-000 255-504 255-504/000-009/999-950 255-504/333-000 255-505 255-505/000-009/999-950 255-505/333-000 255-505/333-006 255-506 255-506/000-009/999-950 255-506/333-000 255-506/333-006 255-507 255-507/000-009/999-950 255-507/333-000 255-507/333-006 255-508 255-508/000-009/999-950 255-508/333-000 255-509 255-509/000-009/999-950 255-509/333-000 255-510 255-510/000-009/999-950 255-510/333-000 255-512 255-512/000-009/999-950 255-512/333-000 255-516 255-516/000-009/999-950 255-524 255-524/000-009/999-950 255-524/333-000 255-600 255-601 255-602 255-602/000-009/999-950 255-602/333-000 255-602/333-009/999-950 255-603 255-603/000-009/999-950 255-603/333-000 255-604 255-604/000-009/999-950 255-604/333-000 255-605 255-605/000-009/999-950 255-605/333-000 255-606 255-606/000-009/999-950 255-606/333-000 255-607 255-607/000-009/999-950 255-607/333-000 255-608 255-608/000-009/999-950 255-608/333-000 255-609 255-609/000-009/999-950 255-609/333-000 255-610 255-610/000-009/999-950 255-610/333-000 255-612 255-612/000-009/999-950 255-612/333-000
- PCB Interconnect
