Datasheet Wago 255-612/333-000 — Даташит
Клеммная колодка для печатной платы; рычаги, управляемые пальцами; 2,5 мм²; Шаг контактов 10/10,16 мм; 12-полюсный; CAGE CLAMP; возможность объединения
Купить 255-612 на РадиоЛоцман.Цены — от 1 385 до 11 553 ₽12 предложений от 9 поставщиков Соединители, Conn Miniature Cylindrical SKT 3POS Crimp ST Cable Mount 3 Terminal 1Port | |||
| 71-255612-08J | 5 308 ₽ | ||
| 71-255612-10S Amphenol | 11 553 ₽ | ||
| 2.55612e+006 | по запросу | ||
| 255612 | по запросу | ||
| Actuation type | Finger-operated lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 23 mm / 0.906 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.402 MJ |
| GTIN | 4044918662659 |
| Height | 22.2 mm / 0.874 inch |
| Height from the surface | 14.2 mm / 0.559 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 10/10.16 mm / 0.394/0.4 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 630 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 25 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Вес | 20.756 г |
| Ширина | 122.9 mm / 4.839 inch |
Серия: 255 (100 из 157)
- 255-504/000-009/999-950 255-504/333-000 255-505 255-505/000-009/999-950 255-505/333-000 255-505/333-006 255-506 255-506/000-009/999-950 255-506/333-000 255-506/333-006 255-507 255-507/000-009/999-950 255-507/333-000 255-507/333-006 255-508 255-508/000-009/999-950 255-508/333-000 255-509 255-509/000-009/999-950 255-509/333-000 255-510 255-510/000-009/999-950 255-510/333-000 255-512 255-512/000-009/999-950 255-512/333-000 255-516 255-516/000-009/999-950 255-524 255-524/000-009/999-950 255-524/333-000 255-600 255-601 255-602 255-602/000-009/999-950 255-602/333-000 255-602/333-009/999-950 255-603 255-603/000-009/999-950 255-603/333-000 255-604 255-604/000-009/999-950 255-604/333-000 255-605 255-605/000-009/999-950 255-605/333-000 255-606 255-606/000-009/999-950 255-606/333-000 255-607 255-607/000-009/999-950 255-607/333-000 255-608 255-608/000-009/999-950 255-608/333-000 255-609 255-609/000-009/999-950 255-609/333-000 255-610 255-610/000-009/999-950 255-610/333-000 255-612 255-612/000-009/999-950 255-612/333-000 255-616 255-616/000-009/999-950 255-624 255-624/000-009/999-950 255-700 255-740 255-741 255-742 255-743 255-743/999-950 255-744 255-746 255-747 255-748 255-750 255-751 255-752 255-753 255-753/999-950 255-754 255-756 255-757 255-758 255-760 255-761 255-762 255-763 255-763/999-950 255-764 255-766 255-767 255-768 255-800 255-801 255-811 255-821
- PCB Interconnect
255612/333000, 255 612/333 000
