Datasheet Wago 256-409 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 5/5,08 мм; 9-полюсный; CAGE CLAMP; возможность объединения
|  Купить 256-409 на РадиоЛоцман.Цены — от 384 до 1 356 ₽ 9 предложений от 8 поставщиков Крепежные Изделия для Кабеля | |||
| 256-409 Wago | 384 ₽ | ||
| 256-409 Wago | 1 076 ₽ | ||
| 25640.9 Conta-Clip | по запросу | ||
| 256-409/334-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 17.6 mm / 0.693 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.131 MJ |
| GTIN | 4044918757188 |
| Height | 22.2 mm / 0.874 inch |
| Height from the surface | 18.2 mm / 0.717 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 9 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 9 |
| Total number of potentials | 9 |
| Вес | 8.74 г |
| Ширина | 47.9 mm / 1.886 inch |
Серия: 256 (100 из 282)
- 256-100 256-200 256-300 256-400 256-401 256-401/332-000 256-402 256-402/000-009/999-950 256-402/332-000 256-402/332-009/999-950 256-402/333-000 256-402/333-009/999-950 256-402/334-000 256-403 256-403/000-009/999-950 256-403/332-000 256-403/332-009/999-950 256-403/333-000 256-403/334-000 256-404 256-404/000-009/999-950 256-404/332-000 256-404/332-009/999-950 256-404/333-000 256-404/334-000 256-405 256-405/000-009/999-950 256-405/332-000 256-405/332-009/999-950 256-405/333-000 256-405/334-000 256-406 256-406/000-009/999-950 256-406/332-000 256-406/332-009/999-950 256-406/333-000 256-406/334-000 256-407 256-407/000-009/999-950 256-407/332-000 256-407/332-009/999-950 256-407/333-000 256-407/334-000 256-408 256-408/000-009/999-950 256-408/332-000 256-408/332-009/999-950 256-408/333-000 256-408/334-000 256-409 256-409/000-009/999-950 256-409/332-009/999-950 256-409/333-000 256-409/334-000 256-410 256-410/000-009/999-950 256-410/332-009/999-950 256-410/333-000 256-410/334-000 256-412 256-412/000-009/999-950 256-412/332-000 256-412/332-009/999-950 256-412/333-000 256-412/334-000 256-416 256-416/000-009/999-950 256-416/332-000 256-416/332-009/999-950 256-416/334-000 256-424 256-424/000-009/999-950 256-424/332-000 256-424/332-009/999-950 256-424/333-000 256-424/334-000 256-425/334-000 256-435/334-000 256-436 256-436/000-009/999-950 256-436/332-000 256-436/332-009/999-950 256-436/334-000 256-448 256-448/000-009/999-950 256-448/332-000 256-448/332-009/999-950 256-448/334-000 256-461 256-500 256-501 256-501/332-000 256-502 256-502/000-009/999-950 256-502/332-009/999-950 256-502/333-000 256-502/333-009/999-950 256-502/333-017 256-502/334-000 256-503
- PCB Interconnect
