Datasheet Wago 256-516/000-009/999-950 — Даташит
клеммная колодка для печатной платы; Нажать кнопку; 2,5 мм²; Расстояние между контактами 7,5/7,62 мм; 16-полюсный; подходит для приложений Ex-e; ЗАЖИМ ДЛЯ КЛЕТКИ; вариант объединения
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 17.6 mm / 0.693 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.325 MJ |
| GTIN | 4044918764582 |
| Height | 22.2 mm / 0.874 inch |
| Height from the surface | 18.2 mm / 0.717 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 16 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current (Ex e II) | 16 A |
| Rated voltage EN (Ex e II) | 275 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 16 |
| Total number of potentials | 16 |
| Вес | 18.676 г |
| Ширина | 122.9 mm / 4.839 inch |
Серия: 256 (100 из 282)
- 256-502/334-000 256-503 256-503/000-009/999-950 256-503/332-000 256-503/332-009/999-950 256-503/333-000 256-503/334-000 256-504 256-504/000-009/999-950 256-504/332-000 256-504/332-009/999-950 256-504/333-000 256-504/334-000 256-505 256-505/000-009/999-950 256-505/332-009/999-950 256-505/333-000 256-505/334-000 256-506 256-506/000-009/999-950 256-506/332-009/999-950 256-506/333-000 256-506/334-000 256-507 256-507/000-009/999-950 256-507/332-009/999-950 256-507/333-000 256-507/334-000 256-508 256-508/000-009/999-950 256-508/332-000 256-508/332-009/999-950 256-508/333-000 256-508/334-000 256-509 256-509/000-009/999-950 256-509/332-009/999-950 256-509/333-000 256-509/334-000 256-510 256-510/000-009/999-950 256-510/332-009/999-950 256-510/333-000 256-510/334-000 256-512 256-512/000-009/999-950 256-512/332-009/999-950 256-512/333-000 256-512/334-000 256-516 256-516/000-009/999-950 256-516/332-009/999-950 256-516/334-000 256-518 256-524 256-524/000-009/999-950 256-524/332-009/999-950 256-524/334-000 256-561 256-600 256-601 256-602 256-602/000-009/999-950 256-602/332-000 256-602/332-009/999-950 256-602/333-000 256-602/333-009/999-950 256-602/334-000 256-603 256-603/000-009/999-950 256-603/332-000 256-603/332-009/999-950 256-603/333-000 256-603/334-000 256-604 256-604/000-009/999-950 256-604/332-009/999-950 256-604/333-000 256-604/334-000 256-605 256-605/000-009/999-950 256-605/332-009/999-950 256-605/333-000 256-605/334-000 256-606 256-606/000-009/999-950 256-606/332-009/999-950 256-606/333-000 256-606/334-000 256-607 256-607/000-009/999-950 256-607/332-009/999-950 256-607/333-000 256-607/334-000 256-608 256-608/000-009/999-950 256-608/332-009/999-950 256-608/333-000 256-608/334-000 256-609
- PCB Interconnect
256516/000009/999950, 256 516/000 009/999 950
