Datasheet Wago 256-609/332-009/999-950 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 10/10,16 мм; 9-полюсный; подходит для применения во взрывоопасных зонах; CAGE CLAMP; возможность объединения
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Габариты: глубина | 17.6 mm / 0.693 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| GTIN | 4017332630573 |
| Height | 23.7 mm / 0.933 inch |
| Height from the surface | 18.2 mm / 0.717 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 9 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 10/10.16 mm / 0.394/0.4 inch |
| Rated current (Ex e II) | 16 A |
| Rated voltage EN (Ex e II) | 275 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 5.5 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 9 |
| Total number of potentials | 9 |
| Вес | 1.111 г |
| Ширина | 92.9 mm / 3.657 inch |
Серия: 256 (100 из 282)
- 256-516/332-009/999-950 256-516/334-000 256-518 256-524 256-524/000-009/999-950 256-524/332-009/999-950 256-524/334-000 256-561 256-600 256-601 256-602 256-602/000-009/999-950 256-602/332-000 256-602/332-009/999-950 256-602/333-000 256-602/333-009/999-950 256-602/334-000 256-603 256-603/000-009/999-950 256-603/332-000 256-603/332-009/999-950 256-603/333-000 256-603/334-000 256-604 256-604/000-009/999-950 256-604/332-009/999-950 256-604/333-000 256-604/334-000 256-605 256-605/000-009/999-950 256-605/332-009/999-950 256-605/333-000 256-605/334-000 256-606 256-606/000-009/999-950 256-606/332-009/999-950 256-606/333-000 256-606/334-000 256-607 256-607/000-009/999-950 256-607/332-009/999-950 256-607/333-000 256-607/334-000 256-608 256-608/000-009/999-950 256-608/332-009/999-950 256-608/333-000 256-608/334-000 256-609 256-609/000-009/999-950 256-609/332-009/999-950 256-609/333-000 256-609/334-000 256-610 256-610/000-009/999-950 256-610/332-009/999-950 256-610/333-000 256-610/334-000 256-612 256-612/000-009/999-950 256-612/332-009/999-950 256-612/333-000 256-612/334-000 256-616 256-616/000-009/999-950 256-616/332-009/999-950 256-616/334-000 256-624 256-624/000-009/999-950 256-624/332-009/999-950 256-624/334-000 256-661 256-700 256-740 256-742 256-742/332-000 256-743 256-743/332-000 256-743/332-000/999-950 256-743/999-950 256-744 256-744/332-000 256-745 256-746 256-746/332-000 256-747 256-747/332-000 256-748 256-750 256-752 256-752/332-000 256-753 256-753/332-000 256-753/332-000/999-950 256-753/999-950 256-754 256-756 256-756/332-000 256-757 256-757/332-000
- PCB Interconnect
256609/332009/999950, 256 609/332 009/999 950
